why welding symbol size is small in inch models when i weld pallete
- July 30, 2012
- 0 replies
- 913 views
Hi buddies,
I am using wildfire 5.0
I have created weld pallet( store the custom weld symbols in drawing called weld pallete). When i use weld symbols from this pallete in mm model , weld symbol apperance size is good. if i use in inch model, the symbol appears in small size.
I have tried to change the drawing units and to inch or created separte weld pallet for inch, changing the attributues in redife weld option. nothing helped.
calling symbols from symbol directory its fine in inch & mm model.
How can i use my drawing pallete in inch model.
Please help.
Thanks Much
Suganthan.R
