Jul 5, 2022 7:24 AM UTC
Wildfire
I am using Creo Parametric Release 6.0 and Datecode6.0.5.1
Hi ,
I need to make a plan of a test bench, and I am missing symbols in Creo parametric. Apparently it's a palette to download (piping palette or other).
I need the following symbols:
_ Manual valve
_ Manometer
_ Vertical container (nitrogen bottle)
_ Safety valve
_ Regulator
Hope to hear you soon.
Sincerely yours,
Christophe.
    Jul 5, 2022 8:06 AM UTC
    Some symbols are missing from the palette and your use case requires them. The palette can be customized and it requires a little preparation.
    The documentation gives the broad instructions to add them. video:  https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/#page/other_modules%2Flegacy%2FTo_Define_a_Symbol.html%23
    Once the symbols are added to your palette, then you'll be good to go.
    here is a video from David Martin: https://www.youtube.com/watch?v=TZLOIb-dUp8 and from 4K side: https://www.youtube.com/watch?v=zJrea53xtG8
