WildFire 4.0 isn't creating MathCad generated parameters
I am having trouble getting ProE to create (or store) parameters generated by MathCad. I've created an analysis feature in a test part that sends parameter data to MathCad, uses it in some calculations, then sends back calculated output variables from MathCad. Everything looks to be working fine in the analysis feature--I hit compute and get correct answers, I can (and do) request parameters to be created, etc; however, when I finish creating the feature, ProE doesn't seem to actually create the parameters. (I.e. no feature parameters show up when I query Info->Feature or Edit->Parameters). I want to use the incoming data from MathCad in relations, but can't make any progress till I get ProE to actually create the MC parameters and store the data.
Any suggestions?
I am using ProE Wildfire 4.0 (build M140) and MathCad13. I jumped back to WF3.0 to see if it would work, but had same problem.
Mike
VladimirNAnswer
Mike,
Parameters do not appear in the list because of discrepancy of units of measure (check up them for the vector of "F"). Unit of measure "N * mm" is not supported when transferring to Pro/E (for example, you can change the measurements to "Joel," and then the parameters will be set up). The list of supported units of measure can be found in the Help file (F1) Pro/E (chapter "Analysis Mathcad and element analysis of Mathcad").
I use versions: Mathcad 15 and Pro/E WF 5.
Hello!
Can you attach files Mathcad and Pro/E?
P.S. Have you used the tags for data transmission ("proe2mc" and "mc2proe")?
MWorley1-VisitorAuthor
Attached is the ProE and MathCad that I'm using.
Mike
VladimirN24-Ruby IVAnswer
Mike,
