Windchill Relationship Report missing mfg.mfg
In process of having a few drawing's released, and seeing an unusual
error.
I have a Cable assembly drawing with the following file added to the drw :
Cable.asm, Cable_Flat.asm, Cable_mfg.asm
For some reason the Cable_mfg.mfg does not come up in the Windchill
relationship report.
I cannot add the Cable_mfg.mfg to the drw, it is part of the Cable_mfg.asm
This was not an issue with WF4 and Intralink, is their a different
proceedure that needs to be done for CREO Parametric 2.0 and CPDM
Windchill?
Douglas Bowles
Electro-Mechanical Design Eng.
520-794-7817
Cell 520-490-9395
20-Turquoise
December 15, 2014
On 12/15/14 13:32, Douglas K Bowles wrote:
> In process of having a few drawing's released, and seeing an unusual error.
> I have a Cable assembly drawing with the following file added to the drw : Cable.asm, Cable_Flat.asm, Cable_mfg.asm
> For some reason the Cable_mfg.mfg does not come up in the Windchill relationship report.
> This was not an issue with WF4 and Intralink, is their a different proceedure that needs to be done for CREO Parametric 2.0 and CPDM Windchill?
Creo Elements/Pro 5.0 (Pro/ENGINEER Wildfire 5.0)
* All manufacturing information will be stored in the .asm file
* Any legacy .mfg file read into Creo Elements/Pro 5.0 is converted to .asm when saving
> Douglas Bowles
> 520-794-7817
> Cell 520-490-9395
> -----End Original Message-----
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
dbowles4-ParticipantAuthor
Thank-You
Douglas Bowles
520-794-7817
Cell 520-490-9395
