Windows 10 version compatibility
I am using Creo Parametric 4.0 and 7.0, there is a plan to upgrade Windows 10 version to 1909 (OS build 18363), need to verify compatibility.
    tbraxton
    PTC documents Creo 4 and Creo 7 (all date codes) as being compatible with Windows 10 64 bit OS. I doubt they have tested with every single windows update so you should test it yourself before deploying it if there are a lot of machines deployed in your environment.
    https://www.ptc.com/en/support/article/cs99145
    @LL_9579900
    You can refer to "operating system levels" under the hardware notes of Creo Parametric from the following article:
    https://www.ptc.com/en/support/article/CS55934
