Wire Spool
I created a wire spool. I routed a wire using the spool. When I go to edit the spool, save is greyed out. It's new, so its not a permission thing-I think? I go to add and remove columns and I can't save it. What's up?
I had to create a color, such as white in my appearance manager and it correlates to the spool color.
when you add/remove columns you just change the appearance of the dialog and not you don't any change to the spool - there is nothing to save ....
I am able to ADD columns and they stay. I can't REMOVE columns, even if I just added them. I've never seen this type of behavior. I don't use cabling much though.
I have another question:
I have color_code and color in columns and it does not change my model. That's basically what I am tring to accomplish.
can elaborate which version of Creo you are using ?
WF_1097191712-AmethystAuthorAnswer
