Wires are twisted at network ends in CREO Cabling
- 3 replies
- 2279 views
- Translate All
Hello everyone,
I hope I'm right here. With CREO-Cabling I have my problems. I want to route 2 wires. Via the spools, I have defined a bending radius that causes problems with the following topic. At the end of a network, the wires are always twisted so that the wires make a loop because of the bending radius. See pictures.
Twisting over the angle does not solve the problem either. How do you manage to run both cables straight and parallel to the end of the network?
Thank you
Marcel
Thank you
Marcel
