Aug 31, 2010 3:14 PM UTC
X Hatching Modify
Have problem choosing x-hatch in a drawing view because no x-hatching lines are visible.
Is there a way to click on x-hatch using filter or any other way?
Sep 3, 2010 2:11 PM UTC
If you put your cursor in the space where the hatch lines should be, hold down the Right Mouse Button, and select Pick From List, you should find the Crosshatch in the list.
Sep 3, 2010 5:33 PM UTC
You can also set the selection filter to X-Section.
