Oct 23, 2025 1:34 AM UTC
一点建议
1:creo12不能检索pro_Library_dir所指定的库中的元件。这是creo12的一个BUG么?因为其它版本的creo是正常的。
2:能不能设置一个选项,可以让功能区按键提示“ALT”被释放出来,用于快捷键比如ALT+1,ALT+F等。功能区按键这个操作太繁琐,按键次数太多并不能起到“快捷”的作用。而且在使用这个功能时因为软件要加载出提示,还会让软件感觉卡顿。再者大多数人并不会用到这个功能,况且还有一个F10可以用来做这个事。为什么ALT与F10两个按键用来做同一个事情呢。还占用ALT这个使用率超高的按键。
建议设置一个选项让用户选择是否使用这个功能,选择不使用这个功能时ALT键可以用来设置快捷键。
Catalina
Community Moderator
Oct 29, 2025 9:26 AM UTC
Hi @XX_10707671
Thank you for your question.
Best regards,
Catalina | PTC Community Moderator
Nov 6, 2025 5:45 PM UTC
pro_library_dir works in Creo 12.0.4.0 for me. I have it directed to a folder in Windchill using the syntax "wtpub://<server name in the server manager>/Libraries/<library name>". Note that the name of the server in the Server Manager MUST match the name used in the path in pro_libary_dir. However, if you're using a local directory, the full path should be fine.
Your second point looks like it should be in a Creo Idea, so it can be considered for future implementation. Drop a link to it in the comments here, if you post one, so we can find it and vote on it.
