3-Newcomer
Animation with Servo Motor and Explosion
Using Creo Parametric 8.0.4.0, is it possible to create an animation using both a servo motor and explode? Attempting to explode/unexplode an assembly, then show rotation using the servo motor. Can these two features be used simultaneously or will separate animations have to be created?
Community Moderator
Hi @AB_12662889,
Thank you for your question.
Anurag
