another WF5 UI complaint
In WF3 and before, there was a status bar at the bottom of the screen
that told the feature name of what was being pre-highlighted. This was
great because the name was populated immediately - where the "tool-tip"
at the cursor pops up after a second - or two - or three...
There were other useful items displayed in this bar that I cannot
remember what they showed. Is anyone seeing this in WF5? If so, do you
know how to turn it on?
I am running M050, Win7 x64.
Thanks.
-Nate
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
The only place to even remotely get any type of information like this is now located at the top left of the screen. The component highlighting in a "message list" is completely gone now. It's actually more difficult to see the intended component nowadays.
Bob
One of these turn that on in WF5 (in the top tool bar), summary_help OR provide_pick_message_always
Funny how many users never used this but I can't live without it.
In Reply to Nathan Rollins:
Thanks.
-Nate
rollinsn1-VisitorAuthor
Thanks Vaughn! Now I just have to train my eyes to go to the top of the
screen instead of the bottom.
I wonder why the default setting for "summary_help" is "no".
We used to be able to set the number of lines visible in the session
info messages, too. Now it defaults to 1 line? That seems pretty
useless...
Nathan,
To add extra message lines,set the config.pro option
visible_message_lines
Dave
David Brainsky
Chula Vista, Ca. 91910
Unless something has changed, the option ‘visible_message_lines’ is useless.  I’ve set it in WF2, WF3 and WF4 and it ends up being 1 no matter what once the dashboard appears.  I tried complaining to PTC and they said “intended functionality” - it only sets the initial visible message lines, does not guarantee a number of lines will always be visible.
It’s ridiculous since most messages are 2-4 lines and the important bits are usually not in the last line.
Item # 2,341,867,631 in the list of small things in Pro/E that block my productivity.
Doug Schaefer
Doug,
You are correct when you state that the message lines switch back to 1 after
the dashboard opens. I actuallypull the dashboard down to reveal more message
lines.I only need to do this one time per module that I am using. IE: Proe,
assembly, mfg, etc.
The message line visibility remainsuntil I exit Proe.
David Brainsky
Anyone have an idea of why some of my sketch dimensions show up with more or less decimal places? I am really confused as to why in the picture on dimension has 3 places and the other dimension has 6 places???
[cid:image004.jpg@01CBBEDB.69740EC0]
Patrick Fariello
CommScope
1300 E. Lookout Drive, Suite 150
Richardson, TX 75082
PH: 972-792-3303
-<">mailto:->
[cid:image003.jpg@01CBBEDB.5D8D07B0]<">http://www.commscope.com/company/eng/solutions/connect_evolve/index.html>
www.commscope.com<">http://www.commscope.com/company/eng/index.html>
________________________________
