Can create surface but not solid with sweep blend
Hi all, I am trying to design a wind turbine blade through using multiple sections (around 40) by using the swept blend feature, however this does not seem to work. When I try to use sweep blending it simply says the model failed to regenerate, yet when I use the surface blending function the model generates just fine. Can anyone help?
Amin
Patriot_1776
Ambiguious question. Try using the surfaces, then solidify?
Sounds like overlapping issue.
Are you sure start points and directions of each section match the others?
