Can we make frictional contact..!!!
I want to apply frictional contact in CLUTCH Assembly..
if i apply d contact beetween driving shaft and driven shaft cone, and apply servo motor to driving shaft, can automatticaly rotate the driven shaft..??
as per practical its rotate, but how to do it in creo..???/
dbodar1-VisitorAuthor
want to make frictional contact in mechanism...
for example, if one surface is rotating and if pressed other surface agaist rotating surface, the pressed surface is also start to rotate due to friction between them.
I used cam connections between components that touch each other and move. Important to enable lift off. I am not sure if it works for you but give it a try.
