Can you please open this file?
- 4 replies
- 2244 views
- Translate All
I am using the Academic Version of Simulate and I would like that someone (with the commercial version) tries to open either the .prt file or just the result window, I attached both files.
Just in case, remember that (in this case) for the result window you must set as working directory the folder "Results", otherwise it won't work.
Thank you.
