Cre0 3.0 Parametric
Hi all,
Trying to use simulate within Creo parametric and get the message: Unable to get required Creo Simulate License. Please contact sales representative.
I have the Educational edition which has a standalone version of Creo Simulate which comes up with the same message.
Can anyone tell me how I can get this to work? I need to use it for coursework. As far as I'm aware, the University is also using the educational version and it works fine.
Thanks, Dave
to be able to run Creo Simulate on your PC, you have to fulfil following requirements:
  • your license file must contain Creo Simulate license (without the license, you are able to run Creo Simulate Lite, only)
  • you have to install Creo Parametric and Creo Simulate a properly configure them
MH
