Creo 2.0 Student Edition Collision Settings
Hi all,
I'm running Creo 2.0 Student Edition. Under Collision Detection Settings>Optional Settings, I only have the option for "Sound Warning on Collision". I'm looking for the option to "Stop when colliding". Is this a limitation on the student edition?
Thanks in advance
Not necessarily. If you have only "Sound warning (..)" option, it may be, because you have only basic collision settings enabled. Try adding enable_advance_collision option to your config.pro and set its value to "yes". It should enable advanced collision settings, which include "Stop when colliding" option. If it doesn't work, then Student Edition may have such limitations indeed.
18-Opal
You can get additional information here:
https://www.ptc.com/en/academic-program/products/free-software
Amit
sycophant1-VisitorAuthor
Worked like a charm. Thank you!
