Creo 3.0 M140 - Reverse Mouse Wheel Not Working
Creo 3.0 M140 - Reverse Mouse Wheel Not Working (Win 10)
My mouse wheel works like this:
Roll the Top of Mouse Wheel Towards the Front of the Mouse -> Zoom OUT
I have added the use_inverted_mousewheel_zoom  Yes to my CONFIG.PRO
No matter if the setting is Yes or No the mouse wheel zoom
function is exactly the same.
I want the mouse wheel to Zoom In when the mouse wheel is rolled
towards the front of the mouse.
Any suggestions?
I tested use_inverted_mousewheel_zoom  YES  in CR3 M110 and M150. It works well in both versions.
IMPORTANT: You have to put the option into config.pro and restart Creo !
I did have it saved into my CONFIG.PRO file...
I feel stupid but I did not know that you had to restart Creo. 😕
I restarted and it IS working now.
None of the posts regarding reversing the mouse wheel mentioned restarting Creo...
THAT was the missing piece to my puzzle!
Thank you!!
Dale_Rosema
Please mark Martin's answer as correct for those who may search on this topic so they know that you found a solution.
