Take a look - "Understand which parameters can be extracted from Flow Analysis": https://community.ptc.com/t5/Analysis/Understand-which-parameters-can-be-extracted-from-Flow-Analysis/td-p/568789
Community Moderator
Hi @SZdore,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
