Jun 30, 2017 2:07 AM UTC
Creo parametric cannot save part file
I have a pro blem when saving creo file. When I click on save. Creo parametric only generate a wrong file folder with the name of "XXX-part.Number". It cannot be open by creo. So all changes are lost. So pitty.
Jun 30, 2017 5:41 AM UTC
1.]
outsideframe_p2.prt.256 is valid name of Creo part
2.]
The fact that you can see .256 extension means that Windows Explorer evaluated this extension as unknown.
3.]
If you set Windows Explorer to display known extension then all your files will be displayed with numerical extension.
Windows 7:
4.]
What happens when you launch Creo and drag&drop outsideframe_p2.prt.256 file from Windows Explorer window to Creo graphics window ?
5.]
Can you upload your problematic file ? I can try opening it.
MH
Leslie1-VisitorAuthor
Jun 30, 2017 6:23 AM UTC
Thanks for Ur quickly reply. can you give me your email address. The website does not allow to upload creo file.
Jun 30, 2017 6:26 AM UTC
to upload file use Browse button located under editing area.
MH
