Creo relations - 'OR' function
Hello there.
Is there an 'OR' function or something similar in creo relations (i'm using creo elements/pro)
I have the following string of code, which is what i would like it to look like
IF C_GEARBOX_CD_DIM == 125 OR 150
XD_GEARBOX = 215
ENDIF
this links the user inputted 'CD' and drives the 'XD'
However, there are many figures for 'CD' that would all provide the same 'XD'
I am trying to get around having to write an if statement for each and every 'CD' (there are 72!!)
Is there a function to allow me to have multiple inputs for an 'IF' function, as my attempt above returned an error as 'OR' doesnt exist
Jonathan
TomUAnswer
Another option may be to check the range and then check for certain conditions. For example, if the number has to be between 125 and 600, and must be on 25 number increments (125, 150, 175, etc.), you could do the following:
/* Check Range
IF C_GEARBOX_CD_DIM >= 125 & C_GEARBOX_CD_DIM <= 600
IF FLOOR(C_GEARBOX_CD_DIM / 25) == (C_GEARBOX_CD_DIM / 25)
XD_GEARBOX = 215
ELSE
XD_GEARBOX = 315
ENDIF
ENDIF
Jonathon,
You need to separate the staements with "|" ( shift on backspace key)
IF C_GEARBOX_CD_DIM == 125|C_GEARBOX_CD_DIM==150
'OR' is the pipe symbol '|'. You have to restate the entire expression though, not just the target values.
IF C_GEARBOX_CD_DIM == 125 | C_GEARBOX_CD_DIM == 150
XD_GEARBOX = 215
ENDIF
You can also use the '\' backslash symbol to continue to multiple lines.
IF C_GEARBOX_CD_DIM == 125 | C_GEARBOX_CD_DIM == 150 | \
C_GEARBOX_CD_DIM == 175 | C_GEARBOX_CD_DIM == 200 | \
C_GEARBOX_CD_DIM == 225 | C_GEARBOX_CD_DIM == 250 | \
C_GEARBOX_CD_DIM == 275 | C_GEARBOX_CD_DIM == 300 | \
C_GEARBOX_CD_DIM == 325 | C_GEARBOX_CD_DIM == 350 | \
C_GEARBOX_CD_DIM == 375 | C_GEARBOX_CD_DIM == 400
XD_GEARBOX = 215
ENDIF
AND is the '&' ampersand.
TomU23-Emerald IVAnswer
/* Check Range
XD_GEARBOX = 215
ELSE
XD_GEARBOX = 315
ENDIF
ENDIF
Hi Tom,
Thank you very much for your responses (and Art!)
The CD dimension is from an imperial decimal number.
IE my datasheet has fractioinal inches and it must be converted to decimal inches when entered in the parameters. there is no specific step between the possible entries so would the following work?
XD_GEARBOX = 215
ELSE
IF C_GEARBOX_CD_DIM >= 601 & C_GEARBOX_CD_DIM <= 900
XD_GEARBOX = 230
ENDIF
ENDIF
Or perhaps write it like this instead?
XD_GEARBOX = 215
ELSE
ENDIF
XD_GEARBOX = 230
ELSE
ENDIF
As an aside, will creo relations recognise fractions in parameters/
IE if a user inputted 2 7/16 in the parameters, could creo use 2.4375 in its calculations? or is this not possible?
