Creo Simulate 2.0 default template?
Hello all,
I am trying to figure out how to change the default Creo simulate results window template.  I have overridden the original template file in the program files directory.  However, this still does not change the results window template to the one I have setup.  Is there any way to change the default results window template?  It gets old having to manually select the one I have setup from my desktop.
Thank you
