Creo/Simulate can you have non-linear and temperature dependent material properties
I need to simulate a manufacturing process and I need to have non linear stress strain and thermal expansion material properties that are temperature dependent. The material changes state at a high temperature and when it cools down because the thermal expansion coefficients are different in the materials as a function of temperature stress/strains are built into these materials as they cool down which I will simulate with a different regions in the material.
Chris3
Yes you can.
Right click in the property field that you want to add dependency to and choose "Function" Then click the new page button and go from there.
