7-Bedrock
Creo simulate lite, compare bending part and un_bend part
I am Sangok An, living in Korea.
I am trying to compare two steel plates—one with bending and one without—using Creo Simulate Lite (9.09). However, the results show that the plate without bending performs better, which is unexpected, and I am not sure about the cause.
Analysis conditions:
  • Material: SUS304
  • Thickness: 6.0 mm
  • Fixation: The steel plate is secured to a concrete floor with four bolts.
  • Load: 100 kgf
I had attached result and parts,
Best your regards
s.o.ahn
skunks
skunksAnswer
it is 1/4 symmetry
Load/4
skunks
Here's my example
JOHNAHN7-BedrockAuthor
7-Bedrock
Dear skunks
Thanks for your quick answer.
I can't understand of load apply points and constrain conditions.
Can you explain more dedail.
One more time thanks for your help.
Best your regards.
s.o.ahn
skunks
skunks19-TanzaniteAnswer
it is 1/4 symmetry
Load/4
