Creo Simulate tag color
I have been looking all over for the setting to change the color of the text in Creo simulate tags (i.e. Dynamic query, Model Max, etc.) In most cases most of the result model is dark blue, it is really difficult to see the black tag text. Is there a way to change it to e.g. a bright manly pink so that is clearly visible at all times? Below is a screenshot clarifying my problem.TAGS.JPG
I'm stupid. 😕
I looked all over. Tried changing all the possibly relevant colors in the System colors menu. Even changed the "Letter" setting about a million times. All the other texts changed color, but the tags remained black. I gave it one more go, and realized that if I change the "Letter" color, the existing tags don't automatically change color. All new tags, however, do.
I could swear I've tried this before, but apparently not. Problem solved.
Mika:
You could try adding a manly pink annotation, but you have to re-enter the modal max and value yourself
Erik
msavolainen1-VisitorAuthorAnswer
I'm stupid. 😕
Mika
At least now you can mark your find as the right answer. Somebody giving the right answers can't be stupid!
Ok, just a little slow then...
