Creo Simulation Live RTX 30xx support (Ampere)
I know that GPUs like a 3080 aren't supported in Simulation live right now - but the interaction is really stange:
Initial click on Sim Live: ~5 min loading for the libarys
Click on Start Simulate: 5 more minutes of loadong (1 CPU is used ~50%) then the simulation starts and is done in 3 secs - when you increase accuracy it only takes the usual time to simulate immediately (5s) and is done
Are there already fixes? When will the support be added?
Thx in advance
There is an article here (Modified: 30-Dec-2021) - "Is the RTX 3090, RTX 6000, RTX 8000 graphics cards support running Simulation Live analysis in Creo Parametric": https://www.ptc.com/en/support/article/CS345782
Still - most other Geforce Cards (Rtx 2070 Super, 1660 Ti-Mobile - with these i have personal experience) run perfectly (3 sec loading - instant Simulation)
Its not about the support - i am just curious because the simulation itself (even when the accuracy is changed) runs perfectly - its just the initial loading.
MfG Raimund
