3-Newcomer
March 24, 2017
Creo slots flipping when dragged
I'm trying to set up a link mechanism using slotted connections.
The link is following the curve, however it will randomly flip 180 degrees when dragged.
http://vvcap.com/0LdTRYLooHa‌‌
I need the holes to always be on the outside face.
PTCs support article on this issue said about putting a third general constraint with the centre planes parallel, but still have the exact same problem after doing this.
Do you have support?
