CREO2 : Reference plane in drawing
I use Creo2. When i put a view in drawing, automatically the references planes appear.
1) Is it possible to desactivate this function ?
2) Is it possible to select all the references planes in the sheet or in a view to suppress them ?
ldrutel1-VisitorAuthor
I have found the solution for my second question.
Select the references plane in the specifical view in the drawing tree
kdirth
This is what the layer tree is for.  Make sure the planes are in a layer in the model and hide the layer in the drawing.
2-Explorer
August 17, 2015
1.1) Try to set your config option display_planes to NO. ---> it hides datum planes when Creo is started
1.2) Put planes in a layer and hide them in your template drw.
1.3) Put planes in a layer and hide them in individual drawings.
Regards
Milan
