11-Garnet
disable Windchill integration on Creo Simulate
is it possible to disable Windchill integration on Creo Simulate.
I would like to use it outside of windchill
@AR_01 wrote:
However, if I also use Creo Elemnts Direct Modeling, in the latter I have to put the windchill server back online every time!
And if I put it online in the workgroup manager, it is also online on Creo Simulate
find Creo Simulate startup file (file with psf extension) and add line similar to the following one at the end of file.
ENV=PTC_WF_ROOT=C:\PTC\Simulate_WF_ROOT
I hope this setting can separate Creo Simulate from Creo Elemnts Direct Modeling.
Should be able to by putting Windchill offline to your Creo session and working out of a disk work location.
AR_0111-GarnetAuthor
11-Garnet
