Feb 1, 2017 9:32 AM UTC
Displacement function of time
I would like to define a determined displacement for a body in the function of time (see attached picture). At the moment, only the fix value is active for the displacement.
How can I define it?
Roland
Feb 1, 2017 1:09 PM UTC
What are you talking about?
Creo Simulate/Mechanica or Mechanism?
In Mechanism do it is very simple, in Simulate you have to define a Dynamic Time Analysis.
rrakos1-VisitorAuthor
Feb 1, 2017 3:14 PM UTC
Sorry....I am talking about the Simulate Mechanica.
I defined a time dependent value in the Static Analysis Definition. This time function is multiplied with the displacement value.
Is is correct?
Roland
Feb 2, 2017 9:32 AM UTC
If I remember well, in a Static Analysis you can't define a load history without nonlinear option such:
  1. contacts,
  2. nonlinear material,
  3. large deformations.
In my opinion, within a static analysis speaking of the time dependence of load/displacements is deceptive because you don't see the"modal" response of the structure that requires a Dynamic Analysis (time or frequency).
In my experience, I've use SA with time dependence only with the ramp and a lot of measure points to obtain a better convergence of a non linear analysis as the three points above.
I'm open to other points of view!
