Doubt in appling load using creo simulate
Hi guys,
This is Ragu from India. I am new to creo simulate. I have a doubt in applying loads on multiple faces while simulating using creo 2.0. I have modeled a flange coupling with 8 holes on a P.C.D of 150. I have selected all the 8 hole surface and applied a load of 500N.
Now the question is, if I do so, whether the software applies the load of 500N to all the 8 holes(i.e for 1st hole, 500N, for 2nd hole, 500N and so on) or it will divide the applied load by 8(i.e 500/8=62.5. For 1st hole 62.5, for 2nd hole 62.5 and so on).
Thanks in advance.
gfrauliniAnswer
The load is equitably divided among the holes surfaces.
If you run a "Review Total load Analysis" you can see that it is 500N, even if you assigned it over multiple surfaces.
Moreover you can see the equitable distribution by running a simple analysis with a force measure over one hole's surface, you can see a value of 62.5 N.
Bye
gfraulini17-PeridotAnswer
Bye
