Feb 2, 2010 9:06 PM UTC
Drawing Rank
Maybe there is a better way to do this but.......
I find deleting models from my drawing that are no longer required very
tedious!
Currently working on a large assembly drawing and need to delete out
many comps.
Process:
File / Properties / Drawing Models / Del Model (List pops up with only 9
models to chose from with a magic arrow to show 4 more at a time! WTF)
so pick on a model name (are you sure Y/N) select yes, and watch the
clock.....tick tock...omg
I have to do this for Every Single Model....talk about madness.
PTC ever here of "Purge" used 20 years ago!!
Arrrrg
Stepping off my soap box now
<jscott>
Jeff Lippeth | Mold Design Engineer | NyproMold | Direct:+1.847.855.2226
This e-mail may contain information which is confidential or privileged.
The information is intended to be for the use of the individual or
entity named above. If you are not the intended recipient, be aware
that any disclosure, copying, distribution or use of the contents of
this e-mail is prohibited.
In the event of any error in transmission, unauthorized recipients are
requested to contact the sender immediately and not to disclose or make
use of this information. No employee or agent is authorized to conclude
any binding agreement on behalf of NyproMold with another party by email
without express written confirmation by NyproMold Offices
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
Feb 2, 2010 9:27 PM UTC
Hey Jeff
Have you tried Model Check… it has an option to find unused models and then you can select them to be removed.
If I remember correctly you have to select 1 model and then remove, then select the next and remove and so on. But still a nice tool to find and remove unused models.
Paul
Paul Mailloux ∫ CAD/CAM Applications Engineer
NyproMold 144 Pleasant St Clinton MA 01510 ∫ www.NyproMold.com
😧 978-368-4598 * F: 978-365-4548
