Encountering Fatal Error in drawings
Encountering fatal error while working within drawings, using Creo Parametric 2.0.  Any ideas?
StephenW
Obviously it's not normal. Is it just one drawing or all drawings. What build code? If I remember right, PTC fixed some recurring issues around build code M090 or M120, maybe sooner.
You might be able to send the traceback file to tech support and they might be able to diagnose the problem.
Certainly not enough information to provide any specific info.  General tip, see if 'update_drawing all' makes the problem vanish.  You can ask Tech Support to investigate, much better with the drawing and trail causing the crash, but possible to look at it with just the traceback.
Are you using GD&T annotation features and applied datum tags?
I stopped using the GD&T datum tags and my crashes all but vanished.
It was unworkable in early Creo 2.  Browse my many rants on this subject here in the community.
Not much luck with support cases either.
Seems it may have been related to the hole features, countersunk thru holes where added with two hole features rather than one thru hole with countersunk included.  Changing them to one feature seems to have helped.
