error during mesh creation
I am using Creo Simulate 4.0 M060
Error message: "Some contacting components have large difference in their tolerance values"
Here are the errors that I faced
    VipulTAnswer
    Hi @HarsadShah,
    • Set the same absolute accuracy for the top assembly , all sub-assembly and components
    • Set config.pro option
      • enable_absolute_accuracy to yes
      • enable_assembly_accuracy to yes
      • default_abs_accuracy to desired value, for instance 0.0001
    • Open each part or assembly separately in standard mode
    • Select File > Properties > Accuracy > change , access to Accuracy dialog box
    • Select Absolute
    • Enter desired value, for instance 0.01
    • Click Regenerate Model
    • Repeat this step for all components of the top assembly and sub-assembly and their components.
    Vipul
    VipulT16-PearlAnswer
    Hi @HarsadShah,
    • Select Absolute
    Vipul
