Error with path
Hello, in creo simulate i have this problem: creo the current working directory contains characters other than alphanumeric and underscore. You cannot mesh, run, ... for this model. Specify an alternative path.
Please how can i fix this issue ? thanks
solution no.1 ... rename working directory
solution no.2 ... use subst command to create new "disk", for example
subst P: "D:\users\user\working directory"
and set P:\ as working directory
