Extract stress range from several load sets....
- April 20, 2015
- 1 reply
- 1168 views
Colleagues,
I have uploaded a Matlab - script that calculates the stress range (Smax-Smin) at all h-nodes in Creo Simulate, for several different load sets. In my case there was a rotating load; I created 12 load sets with 30 degree's pitch.
The script takes the maximum of the maximum principal stress in each node, for all load sets, minus the minimum of the min principal stress for that node, for all load sets. I.e. the stress range that each node feels as the load rotates. This can otherwise be a tedious job - to identify for which load set that we get the max principal, and then look through all of the other load sets to find the minimum principal stress for that point.
It currently works for shell models, I have not verified that it works for solid models.I think that the solid element stress results are reported at different matrix locations as described by PTC's support documents for ASCII result files...
Feel free to use it as you please...
Best regards, Mats L
