Extrusion
Hi!
have you suggestion about extrusion?
The simulation have long duration
How I can speed up the process?
The length is 4500 [mm]
Thank you
skunks
what is the load?
Uniformly distributed load over the entire span of simple beam
So, the load is distributed on the entire surface of the beam
skunks
OK, and constraints?
