Fatal error Creo 3.0 M060: When going to a sheet of a drawing and printing.
I am getting a fatal error when I try and go to sheet 10 of 32 in a drawing.
All of the other sheets in this drawing will let me go to them.
I have attached the traceback.log file of when I went to sheet 10.
I am unable to go to sheet 10 so I can delete it.
I also am unable to print this file due to this error, It appears to crash when it gets to sheet 10.
I tried some of the solutions on the message boards and had no luck.
Any suggestions would be greatly appreciated!
Kindest Regards,
Patti St Jacques
Thank you for all your suggestions.
I found a work colleague who had this same issue with this drawing on his computer last week.
He too was running Creo 3.0 M060.
He was just upgraded to build M080 and this is no longer an issue.
He was able to print this out for me to complete my project. (whew)
I am hopeful that when I get upgraded to M080 that this will no longer be an issue for me.
(fingers crossed!)
Once again thank you all!
Kindest Regards,
Patti St Jacques
I am not sure if my attachment is there.
Below is the traceback.log:
he trace creation timestamp is: Sat Jul 09 17:29:08 16
The executable build timestamp is: Fri Sep 18 04:22:02 15
The datecode is: 2015290
The pro machine type is: x86e_win64
The process ID is: 6852
The traceback type is : CRASH
The logger exit status is: 00003
The release is: 3.0
The external datecode is: M060
The product title is: Creo Parametric
Exception EXCEPTION_ACCESS_VIOLATION has occurred in the thread 10360.
Main Thread 10360
0x000000007721A111 NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xe553768, 0x0, 0x0, 0x8 )
0x00000000770C1A0A NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0xd86ed0, 0x0, 0x1f5f3c00, 0x8c )
0x000007FEF694EF40 NULL (NULL:0) (rtlcoremt:0x000007FEF6940000) ( 0xe553770, 0x52, 0x8dcb90, 0x8dcb90 )
0x000007FEF695005B NULL (NULL:0) (rtlcoremt:0x000007FEF6940000) ( 0x0, 0x1f5f3c00, 0x1, 0x0 )
0x000000014065B2C5 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1f5f3c00, 0x44e8, 0x0, 0x0 )
0x000000014065AD16 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8dcdb0, 0x1f5f3c00, 0xffffffff )
0x00000001406642A9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x0, 0xffffffff )
0x00000001406630AE NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x0, 0x0 )
0x0000000140662823 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x2f6f97f0, 0x1, 0x1f5f3c00, 0x4057361d )
0x00000001406475E7 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x25, 0x2f6f97f0, 0x2d97d880, 0x4 )
0x0000000140795682 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x24, 0x1f5f3c00, 0x1f5f3c00, 0x0 )
0x00000001407918C6 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x10880, 0x1, 0x0 )
0x00000001407913BA NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1f5f3c00, 0x1, 0x2f6f97f0, 0x1f5f3c00 )
0x000000014079403B NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x4, 0x1f5f3c00, 0x18 )
0x0000000140484D36 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x3e9, 0x0, 0x0, 0x17de6fe8 )
0x000000014048ACEF NULL (NULL:0) (xtop:0x000000013F120000) ( 0x57816ca3, 0x49793b28, 0x2, 0x1 )
0x000007FEE0CCA69B NULL (NULL:0) (coretools_sh:0x000007FEE0C30000) ( 0x0, 0x9, 0x1f5f3c00, 0x451f3939 )
0x000000014048E6E9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0xe0c6a1dd, 0x1f5f3c00, 0x404a996c )
0x000000014048A212 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1, 0x1f5f3c00, 0x0, 0x0 )
0x0000000140793F28 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1, 0x0, 0x0, 0x1f5f3c00 )
0x000000014049AACE NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1f5f3c00, 0x0, 0xffffffff, 0x2f577380 )
0x00000001404A5338 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8dd860, 0x1f5f3c00, 0x8dd860, 0xdf4e2a68 )
0x0000000141FDC94A NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8dd860, 0x8dd680, 0x5, 0xdf4e2a68 )
0x0000000141FDE3A9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x1f5f3c00, 0x3b )
0x0000000141FDE09C NULL (NULL:0) (xtop:0x000000013F120000) ( 0xb6, 0x1f5f3c00, 0x1f5f3c00, 0x263f89a0 )
0x0000000141FE1361 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1f5f3c00, 0xb, 0x263f89a0, 0x3e9 )
0x0000000141FE15D4 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x2f6f97f0, 0x3e9, 0x1f5f3c00, 0x263f89a0 )
0x00000001404A53D0 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x4c3a7520, 0x1f5f3c00, 0x604e0ee0, 0xb )
0x00000001404A912E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x17cccae8, 0x0, 0x9, 0x0 )
0x00000001409A5243 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1531a8b0, 0x8ddbf0, 0x0, 0x800000 )
0x000007FEDECFF5BE NULL (NULL:0) (libui_sh:0x000007FEDEA80000) ( 0x1, 0x1531a8b0, 0x8ddcc0, 0x202fdb )
0x000007FEDEC14538 NULL (NULL:0) (libui_sh:0x000007FEDEA80000) ( 0x1531a8b0, 0x800000, 0x1558a800, 0x1558a800 )
0x0000000144A9ECE9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8dde30, 0x0, 0x8ddfd0, 0x0 )
0x0000000144A994E9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8de1f0, 0x75e7088, 0xffffffff )
0x0000000145220122 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x0, 0x0 )
0x0000000145223724 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x23, 0x8de1f0, 0x8de140, 0xffffffff )
0x00000001452207C6 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x23, 0x0 )
0x000000014522B777 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1, 0xffffffff, 0x8de490, 0x49b42590 )
0x0000000145225424 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x6d6d6f43, 0x436f7250, 0x61685376, 0x20736177 )
0x000007FEE0CCA69B NULL (NULL:0) (coretools_sh:0x000007FEE0C30000) ( 0x4976f638, 0x8de619, 0x17cccae8, 0x1f5f3c00 )
0x000000014522B528 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1f5f3c00, 0x17cccae8, 0x17cccae8, 0x4 )
0x00000001402BBDA2 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8de730, 0x8de720, 0x8de730, 0x4976f638 )
0x00000001402BE78F NULL (NULL:0) (xtop:0x000000013F120000) ( 0x73b8f80, 0x5, 0x0, 0xffffffff )
0x00000001402BE98B NULL (NULL:0) (xtop:0x000000013F120000) ( 0x17a6dce0, 0x8de890, 0x17a6dce0, 0xde454883 )
0x000000014200C77C NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x5, 0x8de8f0, 0x0 )
0x000000014202C1FB NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8dec30, 0x0, 0xfffffffe, 0x16066010 )
0x0000000142049696 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x410c2a50, 0x0, 0x0, 0x3 )
0x0000000142049A17 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8dee30, 0x800001, 0xc, 0x73b8f80 )
0x00000001410C296D NULL (NULL:0) (xtop:0x000000013F120000) ( 0xfffffffe, 0x0, 0x4, 0xffffffff )
0x00000001410C1ED9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x73b8f80, 0x4d0ec650, 0x8df190, 0x800001 )
0x000000014201BD8D NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8df190, 0xded72470, 0xded72348, 0xed07c40 )
0x000007FEDECFF5BE NULL (NULL:0) (libui_sh:0x000007FEDEA80000) ( 0x1, 0xeefc6c0, 0x8df260, 0x202fdb )
0x000007FEDEC14538 NULL (NULL:0) (libui_sh:0x000007FEDEA80000) ( 0xeefc6c0, 0x800001, 0x1558a800, 0x1558a800 )
0x0000000144A9ECE9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x8df3d0, 0x0, 0x8df690, 0x0 )
0x0000000144A994E9 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8df6e0, 0x75e7088, 0xffffffff )
0x0000000145220122 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x74e1ca0, 0x74e1ce8, 0x0 )
0x0000000145220870 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x24, 0x0 )
0x000000014522B777 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1, 0xffffffff, 0x8df980, 0x49b42590 )
0x0000000145225424 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x7, 0x0, 0x0, 0x0 )
0x000007FEE0CCA69B NULL (NULL:0) (coretools_sh:0x000007FEE0C30000) ( 0x494b5380, 0x0, 0x3, 0x4267077a )
0x000000014522B528 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x4d9be9c0, 0xa9b130 )
0x0000000142049B79 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x4d9be9c0, 0x3, 0x0, 0x0 )
0x00000001404CEE0A NULL (NULL:0) (xtop:0x000000013F120000) ( 0x4d9be9c0, 0x0, 0x3, 0x3 )
0x0000000146643C6A NULL (NULL:0) (xtop:0x000000013F120000) ( 0x1, 0x8dfa90, 0x3, 0x1 )
0x0000000146643B88 NULL (NULL:0) (xtop:0x000000013F120000) ( 0xa9512d, 0xa, 0xa, 0x0 )
0x0000000140116590 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x0, 0x0 )
0x00000000770B59BD NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0x0, 0x0, 0x0, 0x0 )
Thread 12248
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x1, 0xf15ddd88, 0x0, 0x471fcd8 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x3d10aa0, 0x0, 0x0, 0x274 )
0x000007FEF16026A4 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0xf698e200, 0x2, 0x0, 0xf694cb82 )
0x000007FEF15FC8CD NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3d10aa0, 0x3d186f0, 0x3c76dc8, 0x0 )
0x000007FEF15FC639 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0x3d186f0 )
0x000007FEF15FCA1D NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x3419e50, 0xd, 0x0 )
0x000007FEE4F93FEF NULL (NULL:0) (MSVCR110:0x000007FEE4F70000) ( 0x0, 0x0, 0x0, 0x0 )
0x000007FEE4F94196 NULL (NULL:0) (MSVCR110:0x000007FEE4F70000) ( 0x0, 0x0, 0x0, 0x0 )
Thread 4600
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x13, 0x340032, 0x3411120 )
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x4faf420, 0x4faf410, 0x0, 0xe80000 )
0x00000000770C16D3 NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0x4faf4a0, 0xffffffff, 0x1, 0x324 )
0x0000000076FB8FBD NULL (NULL:0) (USER32:0x0000000076FA0000) ( 0x3d10b20, 0xf1612df0, 0x0, 0x200bf0 )
0x0000000076FB62CE NULL (NULL:0) (USER32:0x0000000076FA0000) ( 0xf698e218, 0xf69421b1, 0xf698e218, 0xf694f460 )
0x000007FEF1602556 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3c76d00, 0x3d10b20, 0x3d23a00, 0xf694cb82 )
0x000007FEF15FC8CD NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3d10b20, 0x3d23a00, 0x3c76dc8, 0x0 )
0x000007FEF15FC639 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0x3d23a00 )
0x000007FEF15FCA1D NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x341a2d0, 0x0, 0x0 )
0x000007FEE4F93FEF NULL (NULL:0) (MSVCR110:0x000007FEE4F70000) ( 0xe5031db0, 0x0, 0x0, 0x0 )
Thread 12284
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x261a1788, 0xd20288, 0xd68b60, 0xf694e10d )
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x592f410, 0x592f3f0, 0x0, 0xfd2810fc )
0x00000000770C16D3 NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0x0, 0x592f740, 0x3d182b8, 0x592f580 )
0x000007FEF15DA7FB NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3d182b8, 0x592f580, 0x10, 0x0 )
0x000007FEF15DA720 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3d182b8, 0xec737f45, 0x1, 0x298 )
0x000007FEF15DA78F NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x869e0cd2, 0x0, 0x1, 0x1 )
0x000007FEF15D6448 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x1, 0x3c97f20, 0x0, 0x0 )
0x000007FEF160265B NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0xf698e200, 0x5, 0x0, 0xf694cb82 )
0x000007FEF15FC8CD NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3c97f20, 0x3d26960, 0x3c76dc8, 0x0 )
0x000007FEF15FC639 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0x3d26960 )
0x000007FEF15FCA1D NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x341dab0, 0x0, 0x0 )
Thread 11268
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x68, 0x1ec00df, 0xfd282d30 )
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x611f3f8, 0x611f3d0, 0x0, 0xf15fcafe )
0x00000000770C16D3 NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0x0, 0x611f720, 0x3d235c8, 0x611f560 )
0x000007FEF15DA7FB NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3d235c8, 0x611f560, 0x10, 0xf15d8304 )
0x000007FEF15DA720 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3d235c8, 0xed1d5db0, 0x1, 0x1 )
0x000007FEF15DA78F NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x86cc64ca, 0x1, 0xee4e9750, 0x1 )
0x000007FEF15D6448 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x1, 0x3d23400, 0x3, 0xee4e9750 )
0x000007FEF16026CB NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0xf6940000, 0x4, 0x0, 0x0 )
0x000007FEF15FD187 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3c76d00, 0x3d23420, 0x3d23e00, 0x3d06710 )
0x000007FEF15FC8CD NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3d23420, 0x3d23e00, 0x3c76dc8, 0x0 )
0x000007FEF15FC639 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0x3d23e00 )
0x000007FEF15FCA1D NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x34209f0, 0x0, 0x0 )
Thread 4864
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x1b, 0x0, 0x772bf550, 0x772bf550 )
0x00000000771DA317 NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x0, 0x0, 0x3ae78e07 )
Thread 10732
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x0, 0x74e18a8, 0x870 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x74d1900, 0x74d1900, 0x0, 0x870 )
0x000007FEDF58D6F4 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x74b1920, 0x0, 0x478 )
0x0000000142F33F0E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x3449700, 0x0, 0x3449700 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x3449700, 0x0, 0xb84030, 0x7fffffff )
Thread 9140
0x000000007720D43A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x3436650, 0x0, 0x0 )
0x00000000771DEBED NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x3436650, 0x0, 0x3436650, 0x0 )
Thread 10652
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x21a0038, 0x11b9b3c0, 0x100002, 0x30 )
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x9adf770, 0x9adf760, 0x0, 0x0 )
0x00000000770B06B0 NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0x0, 0x0, 0x0, 0x0 )
0x000007FEF8E81506 NULL (NULL:0) (NamespaceToEvents_00:0x000007FEF8E80000) ( 0x0, 0x0, 0x0, 0x0 )
Thread 11376
0x000000007720BBCA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x0, 0xfc6d4f60, 0xfc690000 )
0x000007FEFC695711 NULL (NULL:0) (mswsock:0x000007FEFC690000) ( 0xfc695780, 0x7ff1bf0, 0x0, 0x0 )
Thread 9000
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x28, 0xe802a8, 0x7720db18 )
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0xb7cf9f8, 0xb7cf9e0, 0x0, 0xdf4fcd71 )
0x00000000770C16D3 NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0x0, 0xb7cfd30, 0xc5636a0, 0xb7cfb70 )
0x000007FEF15DA7FB NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0xc5636a0, 0xb7cfb70, 0x10, 0x0 )
0x000007FEF15DA720 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0xc5636a0, 0x88f2c217, 0x0, 0xb74 )
0x000007FEF15DA78F NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x6b788ae8, 0x0, 0xffffffff, 0x0 )
0x000007FEF15D6448 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x186affc8, 0xffffffff, 0x186affc8, 0x0 )
0x000007FEF15DA2B9 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x0, 0x3c76d00, 0xf694cb82 )
0x000007FEF15FC8CD NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x3cda760, 0x7455410, 0x3c76dc8, 0x0 )
0x000007FEF15FC639 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0x7455410 )
0x000007FEF15FCA1D NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x344e570, 0x0, 0x0 )
Thread 10488
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x0, 0x0, 0x0 )
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0xc0cfce0, 0xc0cfcd0, 0x0, 0x0 )
0x00000001451A5DB6 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x0, 0x0, 0x0 )
Thread 6980
0x000000007720C0EA NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x82, 0x4a093a, 0xdb0f988, 0x1 )
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0xdb0fa18, 0xdb0f9e0, 0x0, 0x0 )
0x00000000770C16D3 NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0xdb0fa70, 0xffffffff, 0x6, 0x754 )
0x0000000076FB8FBD NULL (NULL:0) (USER32:0x0000000076FA0000) ( 0x1005c2, 0xdb0fc60, 0x0, 0x4a093a )
0x0000000076FB62CE NULL (NULL:0) (USER32:0x0000000076FA0000) ( 0x0, 0xfd287f8a, 0x80000000, 0x0 )
0x0000000076FB6300 NULL (NULL:0) (USER32:0x0000000076FA0000) ( 0x7701208d, 0x0, 0x0, 0x9b112d0 )
0x0000000068F9A3ED NULL (NULL:0) (nvoglv64:0x00000000685C0000) ( 0x0, 0x0, 0x0, 0x0 )
Thread 2068
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x76fb3a47, 0x1db30d0, 0x1 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x9ee0080, 0x68f9efc3, 0x0, 0x770 )
0x0000000068F9F3BA NULL (NULL:0) (nvoglv64:0x00000000685C0000) ( 0x103, 0x186a0, 0x9ee0080, 0x186a0 )
0x0000000068D72BCD NULL (NULL:0) (nvoglv64:0x00000000685C0000) ( 0x9ee0080, 0x0, 0x0, 0x0 )
0x0000000068D72888 NULL (NULL:0) (nvoglv64:0x00000000685C0000) ( 0x0, 0x0, 0x0, 0x0 )
0x0000000068FA1317 NULL (NULL:0) (nvoglv64:0x00000000685C0000) ( 0x0, 0x0, 0x0, 0x0 )
Thread 10996
0x000000007720D43A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x0, 0xb103e0, 0x3434fd0 )
0x00000000771DEBED NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x3434fd0, 0x7, 0x3434fd0, 0x3439400 )
Thread 5776
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x3434600, 0x2, 0x8a39330, 0x8a0 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x74d1918, 0x74d1918, 0x0, 0x8a0 )
0x000007FEDF58D6F4 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x8a38580, 0x0, 0x0 )
0x0000000142F33F0E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8a38580, 0x8a38580, 0x8a39330 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x8a38500, 0x0, 0x8a73050, 0x0 )
Thread 11148
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x9df9100, 0x2, 0x8a38580, 0x8a4 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x74d1930, 0x74d1930, 0x0, 0x8a4 )
0x000007FEDF58D6F4 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x8a38a10, 0x0, 0x0 )
0x0000000142F33F0E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8a38a10, 0x8a38a10, 0x8a38580 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x8a38a00, 0x0, 0x8a730d0, 0x0 )
Thread 10548
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x9df9d00, 0x2, 0x8a38a10, 0x8a8 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x74d1948, 0x74d1948, 0x0, 0x8a8 )
0x000007FEDF58D6F4 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x8a38ea0, 0x0, 0x0 )
0x0000000142F33F0E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8a38ea0, 0x8a38ea0, 0x8a38a10 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x8a38e00, 0x0, 0x8a73150, 0x0 )
Thread 9336
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x342d500, 0x2, 0x8a38ea0, 0x8ac )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x74d1960, 0x74d1960, 0x0, 0x8ac )
0x000007FEDF58D6F4 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x8a397c0, 0x0, 0x0 )
0x0000000142F33F0E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8a397c0, 0x8a397c0, 0x8a38ea0 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x8a39700, 0x0, 0x8a731d0, 0x0 )
Thread 11736
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x11779c00, 0x2, 0x8a397c0, 0x8b0 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x74d1978, 0x74d1978, 0x0, 0x8b0 )
0x000007FEDF58D6F4 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x8a3a570, 0x0, 0x0 )
0x0000000142F33F0E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8a3a570, 0x8a3a570, 0x8a397c0 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x8a3a500, 0x0, 0x9ed9bd0, 0x0 )
Thread 11416
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x8a93600, 0x2, 0x8a3a570, 0x8b4 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x74d1990, 0x74d1990, 0x0, 0x8b4 )
0x000007FEDF58D6F4 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x8a3b320, 0x0, 0x0 )
0x0000000142F33F0E NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x8a3b320, 0x8a3b320, 0x8a3a570 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x8a3b300, 0x0, 0x9ed9cd0, 0x0 )
Thread 11840
0x000000007720BE7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x16b7f698, 0xe0ccb4c9, 0x1, 0x53 )
0x000007FEFD281203 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x4d91eda0, 0x0, 0x0, 0x0 )
0x000007FEDF58EF28 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x4d91eda0, 0x1, 0x0, 0x0 )
0x00000001440EE301 NULL (NULL:0) (xtop:0x000000013F120000) ( 0x0, 0x7fffffff, 0x8a3b300, 0xe0cca8d3 )
0x000007FEE0CCB001 NULL (NULL:0) (coretools_sh:0x000007FEE0C30000) ( 0x0, 0x0, 0x0, 0x8a3b300 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x8a3b300, 0x0, 0x9ed9fd0, 0x7fffffff )
Thread 11392
0x000007FEFD281430 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x193cfa08, 0x193cf9f0, 0x0, 0x68fe8c12 )
0x00000000770B06B0 NULL (NULL:0) (kernel32:0x00000000770A0000) ( 0x11be8980, 0x0, 0x11a27fb0, 0x1 )
0x0000000068FE3F06 NULL (NULL:0) (nvoglv64:0x00000000685C0000) ( 0x0, 0x0, 0x0, 0x0 )
Thread 11476
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0x1, 0x1, 0xf15fc409 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x3c76dc8, 0x0, 0x0, 0x9a0 )
0x000007FEDF4DC745 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x1, 0x3c76dc8, 0x3c76dc8, 0x0 )
0x000007FEF15FC723 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0xefd9d90 )
0x000007FEF15FCA1D NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x118f8da0, 0x0, 0x0 )
Thread 11900
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x3c76dc8, 0x0, 0x0, 0x9ac )
0x000007FEF15FC723 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0x17b47cd0 )
0x000007FEF15FCA1D NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x118f9230, 0x0, 0x0 )
Thread 12236
0x000000007720BE7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x1e1cf6d8, 0xe0ccb64d, 0x0, 0x0 )
0x000007FEFD281203 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x0, 0x0, 0x0, 0x0 )
0x000007FEFA9B1879 NULL (NULL:0) (exitlogger_app_sh:0x000007FEFA9B0000) ( 0x3c, 0x12c, 0x0, 0x118fbfd0 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x118f8d00, 0x0, 0x9edb0d0, 0x0 )
Thread 5636
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x183ccd58, 0xf694ec29, 0x8, 0x8 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x9edb1e8, 0xdf6654c0, 0x0, 0x9f8 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x118f8d01, 0xe84ba8, 0x40 )
0x000007FEDF58CD66 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x118f8d00, 0x0, 0x9edb1d0, 0x7fffffff )
Thread 6592
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x3c76dc8, 0x0, 0x0, 0xa38 )
0x000007FEF15FC723 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0xd86850, 0x0, 0x1885ebe0 )
Thread 9548
0x000000007720BE7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x20f6f618, 0xc9c4013a, 0x1f8ba5b8, 0xc79bb15c )
0x000007FEC8556468 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x0, 0x20f6f630, 0x1f8ba510 )
0x000007FEC8446F9E NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x20f6f730, 0x0, 0x20f6f6e0 )
0x000007FEC851A5F6 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x8a18d48, 0x8a18d48, 0x20f6f730, 0x0 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x118f8d00, 0x0, 0x1f8ba3d0, 0x0 )
Thread 9828
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0xa90000, 0x10, 0xbb8 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x1f8bebb0, 0x1f8bebb0, 0x0, 0xbb8 )
0x000007FECA28CA04 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x1f8ba350, 0x1f8ba350, 0x0, 0x8a18d48 )
0x000007FECA28C878 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x0, 0x8a18bc0, 0x1f6b2618 )
0x000007FEC8564FA1 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1f8ba350, 0x2183f8a0, 0x0 )
0x000007FEC842FE70 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x118f8da0, 0x118f8da0, 0x11c011d0 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x118f8d00, 0x0, 0x1f8ba5d0, 0x0 )
Thread 10572
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0xa90000, 0x10, 0xbc4 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x1f8bec50, 0x1f8bec50, 0x0, 0xbc4 )
0x000007FECA28C878 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x0, 0x8a18bc0, 0x1f6b26b8 )
0x000007FEC8564FA1 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1f8ba350, 0x21fffb40, 0x0 )
0x000007FEC842FE70 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x11c00d40, 0x11c00d40, 0x118f8da0 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x11c00d00, 0x0, 0x1f8ba650, 0x0 )
Thread 10440
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0xa90000, 0x10, 0xbd8 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x1f8bebd0, 0x1f8bebd0, 0x0, 0xbd8 )
0x000007FECA28C878 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x0, 0x8a18bc0, 0x1f6b2758 )
0x000007FEC8564FA1 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1f8ba350, 0x227bf660, 0x0 )
0x000007FEC842FE70 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x11c028a0, 0x11c028a0, 0x11c00d40 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x11c02800, 0x0, 0x1f8ba750, 0x0 )
Thread 8836
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0xa90000, 0x10, 0xbe0 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x1f8beed0, 0x1f8beed0, 0x0, 0xbe0 )
0x000007FECA28C878 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x0, 0x8a18bc0, 0x1f6b27f8 )
0x000007FEC8564FA1 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1f8ba350, 0x22fcf6f0, 0x0 )
0x000007FEC842FE70 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x11c02d30, 0x11c02d30, 0x1fa2c300 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x11c02d00, 0x0, 0x1f8ba7d0, 0x0 )
Thread 10136
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0xa90000, 0x10, 0xbe4 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x1f8bee90, 0x1f8bee90, 0x0, 0xbe4 )
0x000007FECA28C878 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x0, 0x8a18bc0, 0x1f6b2898 )
0x000007FEC8564FA1 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1f8ba350, 0x2380f960, 0x0 )
0x000007FEC842FE70 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1fa2c300, 0x1fa2c300, 0x1fa2d540 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x1fa2c300, 0x0, 0x1f8ba8d0, 0x0 )
Thread 4416
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x0, 0xa90000, 0x10, 0xbdc )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x1f8bee50, 0x1f8bee50, 0x0, 0xbdc )
0x000007FECA28C878 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x0, 0x8a18bc0, 0x1f6b2938 )
0x000007FEC8564FA1 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1f8ba350, 0x23fffdb0, 0x0 )
0x000007FEC842FE70 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x1fa2d540, 0x1fa2d540, 0x11c028a0 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x1fa2d500, 0x0, 0x1f8ba950, 0x0 )
Thread 12216
0x000000007720BE7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x2788fa88, 0x0, 0x0, 0x0 )
0x000007FEFD281203 NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x253ccd70, 0x0, 0x0, 0x0 )
0x000007FEC83C6296 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x0, 0x57816ca8, 0xe84ba8, 0x57816ca8 )
0x000007FECA28C052 NULL (NULL:0) (prowt:0x000007FEC79B0000) ( 0x1fa33000, 0x0, 0x1fb4c0b0, 0x7fffffff )
Thread 9388
0x000000007720D43A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x40000, 0x40000, 0x0, 0x0 )
0x00000000771DEBED NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x3434ee0, 0x7, 0x3434ee0, 0x34371e0 )
Thread 9784
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xff8, 0x1, 0x0, 0x341df900 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0xf165a030, 0x0, 0x0, 0x1cc )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x183de0d0, 0x7, 0x0, 0x183ddfa0 )
0x000007FEF16003C5 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x183de001, 0x0, 0x2591bf00, 0x1885ff40 )
0x000007FEF1600D93 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x2591bf00, 0x0, 0x2591bf00 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x2591bf00, 0x0, 0x1fb4cb30, 0x7fffffff )
Thread 10132
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xff8, 0x1, 0x0, 0x36a7fd20 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x183de200, 0x7, 0x0, 0x183de0d0 )
0x000007FEF16003C5 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x183de201, 0x0, 0x2591bf00, 0x18860130 )
0x000007FEF1600D93 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x2591bf50, 0x2591bf50, 0x2591df40 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x2591bf00, 0x0, 0x1fb4e830, 0x0 )
Thread 11772
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xff8, 0x1, 0x0, 0x372efdd0 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x183ddfa0, 0x0, 0x0, 0x183dde70 )
0x000007FEF16003C5 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x183ddf01, 0x0, 0x2591da00, 0x18860700 )
0x000007FEF1600D93 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x2591dab0, 0x2591dab0, 0x2591e3d0 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x2591da00, 0x0, 0x1fb4e730, 0x0 )
Thread 10576
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xff8, 0x1, 0x0, 0x37c0fa40 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x183dde70, 0x0, 0x0, 0x183de460 )
0x000007FEF16003C5 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x183dde01, 0x0, 0x2591e300, 0x18860510 )
0x000007FEF1600D93 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x2591e3d0, 0x2591e3d0, 0x2591ecf0 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x2591e300, 0x0, 0x1fb4e8b0, 0x0 )
Thread 10404
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xff8, 0x1, 0x0, 0x3845fd70 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x183de460, 0x1, 0x0, 0x183de460 )
0x000007FEF16003C5 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x183de401, 0x0, 0x2591ec00, 0x18860320 )
0x000007FEF1600D93 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x2591ecf0, 0x2591ecf0, 0x2591bf50 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x2591ec00, 0x0, 0x1fb4e930, 0x0 )
Thread 5376
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xff8, 0x1, 0x0, 0x38d6f930 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x183ddc10, 0x4, 0x0, 0x183ddc10 )
0x000007FEF16003C5 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x183ddc01, 0x0, 0x2591ff00, 0x26865a80 )
0x000007FEF1600D93 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x2591ff30, 0x2591ff30, 0x2591dab0 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x2591ff00, 0x0, 0x1fb4ea30, 0x0 )
Thread 11916
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0xff8, 0x1, 0x0, 0x3962fd50 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x183ddd40, 0x5, 0x1, 0x183de200 )
0x000007FEF16003C5 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x183ddd01, 0x0, 0x25920300, 0x26865c70 )
0x000007FEF1600D93 NULL (NULL:0) (asyncoremt:0x000007FEF15D0000) ( 0x0, 0x259203c0, 0x259203c0, 0x2591ff30 )
0x000007FEDF58CB32 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x25920300, 0x0, 0x1fb4eab0, 0x0 )
Thread 9576
0x000000007720BB7A NULL (NULL:0) (ntdll:0x00000000771C0000) ( 0x47a9ef88, 0xdf58a5a2, 0x183cc7e0, 0xf694d9e9 )
0x000007FEFD2810AC NULL (NULL:0) (KERNELBASE:0x000007FEFD280000) ( 0x1fb4eec8, 0x705be6e8, 0x0, 0xf40 )
0x000007FEDF4DC719 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x0, 0x25920301, 0x0, 0x25920300 )
0x000007FEDF58CD66 NULL (NULL:0) (baselibmt:0x000007FEDF4B0000) ( 0x25920300, 0x0, 0x1fb4eeb0, 0x7fffffff )
2-Explorer
July 9, 2016
To save the rest of us guessing what you tried that didn't work, could you include a list?
David Schenken,
I found two different things to try.
I tried them one at a time.
I added the following to my config.pro:
enable_opengl_fbo no
and
graphics win32_gdi
Interestingly the "graphics win32_gdi" did allow sheet 10 to start to load, however it would not load all the way and ended up still crashing.
2-Explorer
July 10, 2016
The win32_gdi setting turns off opengl so other opengl settings won't make a difference.
Has this drawing been opened on this computer?
Have any software changes been made recently?
What graphics card is being used?
Since there's guessing here - is this a complicated assembly with a lot of section views?
What I'm guessing is that one of the sections is being evaluated incorrectly and needs to be changed. If so, it could be as simple as moving the section a small amount. Since Creo performs numerical operations, if there is a condition that causes a failure in a calculation, the calculation will fail and then Creo will crash. Changing where a section is changes the calculation and sometimes avoids a crash.
If this was a drawing and assembly I inherited, I would start by creating a Drawing Program that suppressed all the views on the broken sheet, then change the program to unsuppress / or manually resume them one at a time to narrow the problem down. I don't have specific steps to create a drawing program because I haven't had a drawing sheet break this way. Once the view is narrowed down then the section can be identified.
Alternatives are:
Loading different versions of Creo - there may be a correction made to whatever evaluation is failing.
Send the entire package to PTC to examine and develop a fix in the software.
Perhaps there is some flaw in the data which is causing Creo to fail; send to PTC to find what is broken in the model.
Install a different version of driver software for the graphics card.
Install a different graphics card.
Try an earlier version of the drawing/model and update that to the represent the current version.
Suppress components of the assembly, which should allow the sheet to open, then resume components until it fails. Then examine any sections that pass through that component or any other special conditions that apply to that component.
Looked at the traceback, and was pleasantly surprised the the traceback-unstripping tool wasn't confused by the small changes caused by pasting it on a message board.  The problem occurs in the display of annotations, looks specifically like notes.  I'd recommend calling up Tech Support and saying 'I need this patched posthaste!'  If you just need to locate the problem data to excise it, you might try:
1) Retrieve the drawing, go to Tools > Drawing Representation, tell it to turn off all the views on sheet 10, see if you can get to sheet 10 now, and delete views, notes, or the entire sheet as needed to make it not crash.  Once it doesn't crash, rebuild these things.  [Side note, in a similar situation where it is the initial sheet, File>Open>[drawing]>Open rep>No Views]
2) With the programmatic APIs (Toolkit, J-link, etc.) you don't need to visit sheet 10 to interrogate stuff about it and delete things.
But you're probably better off getting it patched  than rebuilding the sheet, so I'd recommend the SPR route.
pst.jacques1-VisitorAuthorAnswer
(fingers crossed!)
Kindest Regards,
Patti St Jacques
