FEM analysis of disc spring
I have to analyze 5 disc spring in series,
can I ask you any suggest for the analysis?
Looking on internert, I had found many papers only about single disc spring,
I have doubt that maybe it is not necessary analyze all series of 5 disc spring....
I would like to verify the force calculated anilitically for displacement known
Thank you for every help possible
Thank you
skunks
So how to connect the edges between every disc spring? I thank to use a "contact interfaces" but it Is not possibile with the edges..
skunks
better analytically
