Finite friction not supported for small displacement?
  • August 4, 2017
  • 3 replies
  • 2245 views
I'm trying to use a finite friction contact interface, but I'm getting the warning
"The analysis is invalid because finite contact interface is not supported for small displacement analysis."
This implies I should be using large displacement analysis... but that's greyed out so I can't select it.
What am I doing wrong?
skunks
Jonathan,
yes: info
regards
paul
Thanks!
From that, I'm doing two things wrong: I have an advanced spring (which I can get rid of), and fasteners (which are directly related to the finite friction I want to evaluate).
So currently it can't evaluate slippage of a bolt flange, at least not using fastener elements to create the preload?
I'm not sure finite friction is working properly yet.
Does someone have an update?
A non-exhaustive list of things disallowed when using large deflection
Beams, advanced springs, ground springs, fancy shells, weighted links ...
bfn
