Gravity load in creo simulate
Hello Team,
I am trying to add gravity load along with other applicable forces.
Without adding gravity load, simulation goes fine but when i apply gravity load, it fails.
It shows below error: Can you please suggest what could be the reason for this? I am really under pressure to finish the simulation. Any help will be really appretiated.
The design study terminated abnormally.
The nonlinear iteration did not converge for the
time value:   3.90625e-03
  o The model may have a buckling mode with a load factor
    smaller than this value. You may determine the smallest
    (linear) buckling load factor by running a buckling
    analysis.
  o The deformations may be large enough that you must
    further refine the mesh. To locate potential problem
    areas, it may help to run an analysis with reduced
    loads and examine the deformed shape of the model.
  o The model may have a static instability.
  o  It is possible that the load is too large for the model's
     material or the model is insufficiently constrained. Check
     the constraints and material properties, or reduce the maximum load.
Hi @AS_10540676
Could you kindly upload the model to the topic?
