3-Newcomer
Oct 31, 2026 8:52 PM UTC
Have a model with advanced simulation features from last year student version. Can't run the model on current student version. Suggestions?
The error message states some advanced resources used previously, like advanced springs and weighted links, can no longer be used with the current student license.
Hello.
I currently have a CAD model I’ve ran some analysis last year using the student version. I’ve used some “weighted links” and “advanced springs”.
I recently updated the license with student version still for university research as an undergaduate student. However, I can’t run the model with the license anymore.
Is there any way out, is it possible to have a few days trial on the advanced simulate so I can at least finish the model or edit it without losing the information I’ve previously studied?
For instance, I have damping coefficients and the values spring stiffness I’d like to recall.
It would be great if I could run some more analysis on that model. Even if it was for a couple of days.
Thanks for the support.
    Nov 2, 2026 8:15 AM UTC
    Hi
    The error message roughly says :
    Advanced entities have been detected in the model:
    • advanced molds
    • welded structures
    • advanced analysis
    Creo Simulate cannot be used without acquiring the required advanced license needed to work with these entities.
    Please contact your sales representative.
    One of two things is to compare your license files and confirm the license feature lists are identical.
    3-Newcomer
    Nov 2, 2026 7:00 PM UTC
    The licenses are probably different. The problem is: last year, student version incuded all those features. Current student version does not.
    Now I can’t even open the assembly with its simulation features.
    Even if i tried to run a simulation on a comercial version, it would probably block it, since it was made in a student version.
    The work I’ve done is pratically stuck.
    Nov 3, 2026 11:41 AM UTC
    I’m sorry to hear it.
    Student files are unsupported by commercial versions.
    The best course of action is to reach out to your license supplier.
