Hello,how is possible to make a simulation of free fall in creo?thank you very much
How to made a simulation of free fall in creo parametric?thank you
18-Opal
January 20, 2016
Hi Andrej,
You will need to use 3D contact connection with Gravity enabled in Mechanism Dynamics Option (MDO).  You can find more information in the Help Center:
Mechanism Design and Mechanism Dynamics Overview
Amit
ahinic1-VisitorAuthor
can you expain little bit more,i have mode in creo parametric,this model doesnt have mass for now,first i need somewhere put a mass and then something with gravity to do,but i dont know how to putt mass in kg to this model and then....THANK YOU
18-Opal
January 27, 2016
Hi Andrej,
First to assign the units to the model, go to File > Prepare > Model Properties > Units > change.  Select the desired units (mmNs) from the Units Manager and click on Set.
After the units are set click on Mass Properties > change from the Model Properties window.  In the Mass Properties window click on Generate Report > Close > OK.  This will assign mass to the model along with the other mass properties.
Amit
