Help with the hole function
I am trying to use the sketch option in the hole function. I have sketched what i want my hole to look like, but I keep getting an error that says the section is incomplete. I have attached a screen shot of my sketch. When I get the error, little red crosshairs show up on almost every intersection.
D
KevinAnswer
You only sketch half of the hole geometry like a revolved feature. You also need to trim out the inner lines to create a single closed loop (you currently have multiple closed loops).
Kevin1-VisitorAnswer
Thank you kevin,
I got it to work.
D
