Hole Note Updates
Hi Gang
I use custom .hol files to drive my notes for ISO, NPT, UNC, and UNF threads
Enabled my config.pro to look at the directory where the Note files reside.
If make an adjustment to the .hol file, fire up CREO and open the model, redefine the hole, reset the note, all is good
My question;
How do I reset all the holes at the same time, a mass update
IE. If the hole is copied around the model I must manually reset all the holes to get updated.
<jscott>
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
jlippeth1-VisitorAuthor
Added software version
