Holes Spread Sheet
Hi All,
I wanted to creat some new spread sheet for the standard hole function.
Any idea on the effect on previously modeled parts & assy if I modified the spread sheet.
My intention was to split the iso table in to fine thread and coarse thread.
Nicolas
Hello Nicolas
If you need to add a new hole table, so here is one example (see attachment).
Note: You can set your own configuration option: hole_parameter_file_path
nico741-VisitorAuthor
Thanks Vladimir,
Any idea on what happen on previously modeled components if a holes table is removed?
Nicolas
I think you have an error in the hole file and therefore do not display the list.
Vladimir
