How can I change the unit of measure in the Linearized Stress report?
How can I change the unit of measure (from kPa to mPa) in the Linearized stress report?
thank you
How were you able to create the report of stressed with curves.
You had to create the two points on the piece to create the
tables.
Come the three curves.
Would you have the file as an example.
Kind regards.
Denis
Thanks for the reply and the file.
I'll look at how this is done, because I find this
very interesting representation.
Kind regards.
Denis
Thanks for the link.
I will take over all of this, once the update of Creo 3.0 M100
installed.
Kind regards.
Denis
