How do I highlight part of a surface with an annotation feature?
Hi
I want to place an annotation feature on a part and when you click it part of a surface should be highlighted.
This is possible if I split the surface first but as the entire surface is coherent I can't use the split surface function as it doesn't support to split with a sketch.
Is there a way to highlight part of a surface or create a split surface using sketches?
Can it be solved in another way?
Best regards
Zacharias
18-Opal
September 14, 2016
Hi Zacharias,
Are you OK with creating a sketched surface and then selecting that as the annotation feature reference?  You could create a sketch on an existing surface and create a Fill feature to fill in the sketch.  Then you can select just the Fill feature as reference to the Annotation Feature.
Amit
