Jan 9, 2018 4:48 PM UTC
How to create shaft supports for a dynamic analysis in mechanismus? Aim of the analysis is to calcul
Aim of the analysis is to calculate the forces in the support points during rotation of the shaft. The shaft is loaded with a constant force and the weight on the right hand side.
If 2 GIMBAL supports are used the rotation of the shaft during a dynamic analysis does not work. If one “DREHGELENK” or “ZYLINDER” support is used the rotation with the servomotor works but the support forces and the support moments are not correct.
