3-Newcomer
How to plot average pressure from multiple monitoring points in Creo Flow Analysis XY Plot?
I am trying to plot the average pressure from several monitoring points in Creo Flow Analysis / Creo 12.
I have 10 monitoring points named
Point 01, Point 02, ... Point 10
According to the documentation, I understood that monitoring point values can be accessed using syntax like:
flow.P@probe."Point01"
and that user-defined XY plot variables should be created using:
plot.varname
So I tried defining an expression like:
plot.P_avg = (flow.P@probe."Point 01" + [...] + flow.P@probe."Point 10")/10
#plot.P_avg: Average Pressure [Pa]
However, I cannot find plot.P_avg as a selectable variable in the XY Plot panel or elsewhere afterwards.
Has anyone successfully plotted an average value from multiple monitoring points in Creo Flow Analysis?
Am I missing a specific place/context where the expression must be created, or is there another syntax required?
Thanks in advance.
