How to set MDO Parameter MAX and MIN Value within a certain range for BMX
- 1 reply
- 92 views
- Translate All
I would like to set Measured MAX and MIN Value in MDO within a certain range for BMX Constraint.
Model Motion is Rotating 0~90 degree range and MAX and MIN value in whole degree range can be selected in BMX without setting
But are there any way to set MAX and MIN value in a certain degree range (i.e. 30~60deg)?
(attached file is simple model for this question. so, I hope solution wihtout modifying MDO setting)
